[Geoserver-devel] [jira] (GEOS-5816) Error with WCS 1.0 and GetCoverage with bilinear interpolation
Simone Giannecchini created BugGEOS-5816
Issue Type:
BugBug
Affects Versions:
2.3.2, 2.4-beta
Assignee:
Andrea Aime
Components:
WCS
Created:
16/May/13 5:22 PM
Description:
The problem is appears with Geoserver 2.3.0 & WCS 1.0.0.
The interpolation method is offered with the Describe Coverage method of a dataset, e.g.
?SERVICE=wcs&VERSION=1.0.0&REQUEST=DescribeCoverage&identifiers=
wcs:supportedInterpolations
wcs:interpolationMethodbilinear/wcs:interpolationMethod
wcs:interpolationMethodbicubic/wcs:interpolationMethod
/wcs:supportedInterpolations
But when the GetCoverage request is send:
?SERVICE=wcs&VERSION=1.0.0&REQUEST=GetCoverage&coverage=&BBOX=213372.0,5546300.0,563967.0,6095248.0&CRS=EPSG:32632&band=3&resy=250.03352&resx=250.03511&format=GeoTIFF&responsecrs=EPSG:32632&interpolationMethod=bilinear
the following exception is thrown:
<?xml version=“1.0” encoding=“UTF-8”?>
Failed to set property INTERPOLATIONMETHOD in request object using value bilinear of type class java.lang.String java.lang.String cannot be cast to net.opengis.wcs10.InterpolationMethodType
It does not matter whether bilinear or bicubic is chosen as an interpolation method.
Fix Versions:
2.4-beta, 2.3.3
Project:
Priority:
MinorMinor
Reporter:
Simone Giannecchini
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
