Issue Type:
Bug
Affects Versions:
2.4-beta
Assignee:
Andrea Aime
Components:
Security
Created:
19/May/13 10:53 PM
Description:
Online tests must not assume that they have exclusive access to network ports:
http://docs.geoserver.org/latest/en/developer/programming-guide/testing/index.html#online-tests
Online tests should use a configurable fixture (like GeoTools OnlineTestCase or OnlineTestSupport), fail gracefully, or mock network resources.
If LDAP services are already running on a host, LDAPAuthenticationProviderTest fails:
org.apache.directory.shared.ldap.exception.LdapConfigurationException: Failed to bind an LDAP service (10389) to the service registry. [Root exception is java.net.BindException: Address already in use]
at org.apache.directory.server.jndi.ServerContextFactory.startLDAP0(ServerContextFactory.java:499)
at org.apache.directory.server.jndi.ServerContextFactory.startLDAP(ServerContextFactory.java:413)
at org.apache.directory.server.jndi.ServerContextFactory.afterStartup(ServerContextFactory.java:212)
at org.apache.directory.server.core.DefaultDirectoryService.startup(DefaultDirectoryService.java:239)
at org.apache.directory.server.core.jndi.AbstractContextFactory.getInitialContext(AbstractContextFactory.java:118)
at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:667)
at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:288)
at javax.naming.InitialContext.init(InitialContext.java:223)
at javax.naming.InitialContext.<init>(InitialContext.java:197)
at javax.naming.directory.InitialDirContext.<init>(InitialDirContext.java:82)
at org.geoserver.security.ldap.LDAPAuthenticationProviderTest.startApacheDirectoryServer(LDAPAuthenticationProviderTest.java:125)
at org.geoserver.security.ldap.LDAPAuthenticationProviderTest.initLdapServer(LDAPAuthenticationProviderTest.java:66)
at org.geoserver.security.ldap.LDAPAuthenticationProviderTest.testUserFilterAndFormat(LDAPAuthenticationProviderTest.java:244)
Caused by: java.net.BindException: Address already in use
at sun.nio.ch.Net.bind(Native Method)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:124)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:59)
at org.apache.mina.transport.socket.nio.SocketAcceptor.registerNew(SocketAcceptor.java:429)
at org.apache.mina.transport.socket.nio.SocketAcceptor.access$900(SocketAcceptor.java:52)
at org.apache.mina.transport.socket.nio.SocketAcceptor$Worker.run(SocketAcceptor.java:258)
at org.apache.mina.util.NamePreservingRunnable.run(NamePreservingRunnable.java:43)
at java.lang.Thread.run(Thread.java:662)
Project:
Priority:
Critical
Reporter:
Ben Caradoc-Davies
If you think it was sent incorrectly, please contact your JIRA administrators
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
