Christian Mueller created GEOS-5824 |
Issue Type: |
Bug |
Affects Versions: |
2.3.2 |
Assignee: |
Components: |
Security |
Created: |
23/May/13 8:33 AM |
Description: |
The GeoServer start url http://…/geoserver matches the default security chain (handling OGC services). The request is finally redirected to As a consequence, http://…/geoserver should match the web filter chain. A more detailed description is here The Web filter chain has the following ant patterns /web/** Adding the pattern / solves this problem. Unfortunately a data directory migration is required. (A small one, but it is one). Workaround for 2.3.x series: On the GeoServer “Authentication” page, click on the filter chain called “web”. There is a list of ant patterns. /web/,/gwc/rest/web/ Change the list to /web/,/gwc/rest/web/,/ Click close. Back on the “Autentication” page, click “Save”. Finished. |
Project: |
Priority: |
Major |
Reporter: |
