Issue Type:
Bug
Affects Versions:
2.3.2
Assignee:
Andrea Aime
Components:
GWC
Created:
28/May/13 12:05 PM
Description:
Some issues with disk quota using external database:
I missed the “Target database type”, my error wasn’t as clear which field I’d failed to fill in as it should have been:
“Field ‘dialectChooser’ is required.”
The “password” field is never pre-filled in, so I need to fill it in every time I want to change anything on the quota.
If this is for security, I’d point out that the password field in “stores” is pre-filled. I’m not saying which is right, but it should be inconsistent.
I have “Strong PBE” encryption for passwords enabled. But the password is stored in plain text in geowebcache-diskquota-jdbc.xml!!!
Project:
Priority:
Major
Reporter:
Jonathan Moules
If you think it was sent incorrectly, please contact your JIRA administrators
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
