Mauricio Pazos created GEOS-5830 |
Issue Type: |
Bug |
Affects Versions: |
2.3.2 |
Assignee: |
Components: |
WMS |
Created: |
30/May/13 4:29 AM |
Description: |
The improvement done in http://jira.codehaus.org/browse/GEOS-572 publishes, in the WMS Capabilities document, the ScaleHint and ScaleDenomentator based on the Max/Min scale denominator present in the SLD asociated to the layer. This isn’t exactly the expected value by the client. From WMS implementation spec it is necessary a computation based on a Pixel Size that is defined as 0.28mm x 0.28mm |
Fix Versions: |
2.3.3 |
Project: |
Priority: |
Major |
Reporter: |
