[Geoserver-devel] [jira] (GEOS-5842) List of drives is invisible for Adding store
Jonathan Moules created BugGEOS-5842
Issue Type:
BugBug
Affects Versions:
2.3.2
Assignee:
Andrea Aime
Components:
UI
Created:
06/Jun/13 6:07 AM
Description:
If I go to add a store, for “Connection Parameters” I click “browse” which brings up the navigator.
If I click the drop-down box, it only shows “Data Directory” and “Home” Drive "C:" and Drive "D:" aren’t visible but ARE there (I can click where they should be).
I’m 99% certain this issue wasn’t in 2.3.0 (and probably 2.3.1) - I added my stores with no problem there. I suspect this was created as a result of 2.3.2 - “A new option to limit the file browser to the data directory, geared towards high security/multi-tenant environments”
I haven’t enabled that (don’t even know where it is).
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
