Jonathan Moules created GEOS-5873 |
Issue Type: |
Bug |
Affects Versions: |
2.3.3 |
Assignee: |
Components: |
Wicket UI |
Created: |
02/Jul/13 6:34 AM |
Description: |
If I create a new SLD and give it a name of “OS VMD - Line - Roads (minor\local\pedestrian)” GeoServer will error out when I press submit. I get “Oops, something went wrong…” org.apache.wicket.WicketRuntimeException: java.io.FileNotFoundException: D:\GeoServer_Config_Dir\styles\OS VMD - Line - Roads (minor\local\pedestrian).sld (The system cannot find the path specified) at org.geoserver.wms.web.data.StyleNewPage.onStyleFormSubmit(StyleNewPage.java:61) at org.geoserver.wms.web.data.AbstractStylePage$1.onSubmit(AbstractStylePage.java:109) at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1565) at org.apache.wicket.markup.html.form.Form.process(Form.java:958) at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:920) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) |
Project: |
Priority: |
Major |
Reporter: |
