[Geoserver-devel] [jira] (GEOS-5889) LocalResolveTest.testResolveTimeOut intermittent online failures
Ben Caradoc-Davies created BugGEOS-5889
Issue Type:
BugBug
Affects Versions:
2.4-beta
Assignee:
Rini Angreani
Components:
Application schema
Created:
17/Jul/13 3:00 AM
Description:
app-schema-test LocalResolveTest.testResolveTimeOut fails intermittently when run as an online test:
https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master-app-schema-online-test/
Sometimes it fails against Oracle, but more often it fails against PostGIS at a different spot. The tested code in AbstractMappingFeatureIterator.setAttributeContent has a dodgy thread-polling loop. Furthermore, the WFS 2.0.0 spec states that resolveTimeOut must be a positive integer, so should not be zero as in this test.
Oracle Failure:
Failed tests:   testResolveTimeOut(org.geoserver.test.LocalResolveTest): expected:<[urn:x-test:GeologicUnit:gu.25699]> but was:<[]>
Tests run: 142, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ........................ SUCCESS [2.964s]
[INFO] Application Schema Integration Test ............... SUCCESS [22:49.569s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [12.452s]
[INFO] Application Schema Integration Online Test with Oracle Database  FAILURE [12:48.809s]
[INFO] Application Schema Integration Online Test with Postgis Database  SKIPPED
[INFO] BUILD FAILURE
PostGIS failure:
Failed tests:   testResolveTimeOut(org.geoserver.test.LocalResolveTest): expected:<[gu.25699]> but was:<[]>
[INFO]
[INFO] Application Schema Support ........................ SUCCESS [1.830s]
[INFO] Application Schema Integration Test ............... SUCCESS [21:40.652s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [12.708s]
[INFO] Application Schema Integration Online Test with Oracle Database  SUCCESS [12:14.232s]
[INFO] Application Schema Integration Online Test with Postgis Database  FAILURE [2:23.777s]
Project:
Priority:
MajorMajor
Reporter:
Ben Caradoc-Davies
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
