Jonathan Moules created GEOS-5894 |
Issue Type: |
Bug |
Affects Versions: |
2.3.3 |
Assignee: |
Components: |
GWC |
Created: |
18/Jul/13 9:20 AM |
Description: |
My GeoServer is failing to respond to WMTS getCapabilities requests properly. The page I get back simply contains the GWC logo and then the text “400: null”. The service is enabled; TMS works fine. I’m using the URL from the GeoServer admin page: With logging turned up to Geotools DEBUG, I only get two lines in my log: 2013-07-09 15:53:27,451 ERROR [org.geowebcache.GeoWebCacheDispatcher] - null http://wppgeog3:8082/geoserver/gwc/service/wmts WMS via GWC also gives this error: Through GeoServer itself, WMS 1.1.1 and WFS requests are fine (WMS 1.3.0 http://jira.codehaus.org/browse/GEOS-5893 - may or may not be related - but this one happens whether logged in or not), however WCS is failing (http://jira.codehaus.org/browse/GEOS-5882). It doesn’t seem to matter if “Enable direct integration with GeoServer WMS” is enabled or disabled. |
Project: |
Priority: |
Major |
Reporter: |
