[Geoserver-devel] [jira] (GEOS-5932) Different wkt for standard EPSG code between GDAL and GeoServer
Christophe Delépine created BugGEOS-5932
Issue Type:
BugBug
Assignee:
Andrea Aime
Created:
26/Jul/13 4:36 AM
Description:
Using the reprojection console, i did a conversion from EPSG:4326 (WGS84) to EPSG:2192 (lambert).
Then i did the same using GDAL/OGR C++ API (latest 1.10 version) and i get different results :
GDAL :
6 48 => 873359.875296 2339884.925806
GeoServer :
6 48 => 873357.4736901815 2339884.430176288
I then compared the wkt for EPSG:2192 between GDAL and GeoServer and the parameter TOWGS84 is different :
GDAL : TOWGS84[-87,-98,-121,0,0,0,0]
GeoServer : TOWGS84[-116.641, -56.931, -110.559, 0.893, 0.921, -0.917, -3.52]
If i use geoserver’s wkt string to create the GDAL/OGR spatial reference, then the conversion result returned by GDAL is now much closer to geoserver :
6 48 => 873357.473915 2339884.425400
So my question is : why is this parameter different ? Aren’t EPSG codes supposed to be standard ?
Project:
Priority:
MinorMinor
Reporter:
Christophe Delépine
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
