[Geoserver-devel] [jira] (GEOS-5941) Error - ELEM_INFO STARTING_OFFSET
Jonathan Moules created BugGEOS-5941
Issue Type:
BugBug
Affects Versions:
2.3.3
Assignee:
Andrea Aime
Components:
Oracle
Created:
29/Jul/13 5:58 AM
Description:
My GeoServer has started to throw up an error when I try and render one (or may more) of the layers. The exact numbers of the offset and length in the error vary.
I’ve attached the results of running the below query in a text file. The data itself doesn’t seem bad - it passes FME validation and Oracle validation.
2013-07-23 08:38:54,603 DEBUG [org.geotools.rendering] - Processing 1 stylers for http://www.warwickshire.gov.uk/public_data_db:OS_VMD_BUILDING
2013-07-23 08:38:54,603 DEBUG [org.geotools.rendering] - creating rules for scale denominator - 20,000
2013-07-23 08:38:54,603 DEBUG [org.geotools.rendering] - Expanding rendering area by 2 pixels to consider stroke width
2013-07-23 08:38:54,603 DEBUG [org.geotools.rendering] - Querying layer http://www.warwickshire.gov.uk/public_data_db:OS_VMD_BUILDING with bbox: ReferencedEnvelope[458740.8 : 464497.6, 258036.79999999996 : 263793.6]
2013-07-23 08:38:54,603 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2013-07-23 08:38:54,603 TRACE [org.geotools.core] - ENTRY 4
2013-07-23 08:38:54,603 DEBUG [org.geotools.filter] - exporting PropertyName
2013-07-23 08:38:54,603 DEBUG [org.geotools.jdbc] - SELECT SDO_GEOMETRY as SDO_GEOMETRY FROM OSMM.OS_VMD_BUILDING WHERE SDO_FILTER(SDO_GEOMETRY, ?, ‘mask=anyinteract querytype=WINDOW’) = ‘TRUE’
2013-07-23 08:38:54,618 DEBUG [org.geotools.data.oracle.sdo] - Using layer SRID: 27700
2013-07-23 08:38:54,618 DEBUG [org.geotools.jdbc] - Setting parameter 1 as MDSYS.SDO_GEOMETRY(2003,27700,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(458740.8,258036.79999999996,464497.6,263793.6))
2013-07-23 08:38:54,618 DEBUG [org.geotools.jdbc] - 1 = POLYGON ((458740.8 258036.79999999996, 458740.8 263793.6, 464497.6 263793.6, 464497.6 258036.79999999996, 458740.8 258036.79999999996))
2013-07-23 08:38:54,665 ERROR [org.geotools.rendering] - ELEM_INFO STARTING_OFFSET 393 inconsistent with ORDINATES length 197
java.lang.IllegalArgumentException: ELEM_INFO STARTING_OFFSET 393 inconsistent with ORDINATES length 197
at org.geotools.data.oracle.sdo.SDO.createPoint(SDO.java:2463)
at org.geotools.data.oracle.sdo.SDO.createCollection(SDO.java:3000)
at org.geotools.data.oracle.sdo.SDO.create(SDO.java:2429)
at org.geotools.data.oracle.sdo.SDO.create(SDO.java:2383)
at org.geotools.data.oracle.sdo.GeometryConverter.asGeometry(GeometryConverter.java:125)
at org.geotools.data.oracle.OracleDialect.readGeometry(OracleDialect.java:506)
at org.geotools.data.oracle.OracleDialect.readGeometry(OracleDialect.java:492)
at org.geotools.data.oracle.OracleDialect.decodeGeometryValue(OracleDialect.java:455)
at org.geotools.jdbc.JDBCFeatureReader.next(JDBCFeatureReader.java:310)
at org.geotools.jdbc.JDBCFeatureReader.next(JDBCFeatureReader.java:70)
at org.geotools.data.store.ContentFeatureCollection$WrappingFeatureIterator.next(ContentFeatureCollection.java:145)
at org.geotools.data.store.ContentFeatureCollection$WrappingFeatureIterator.next(ContentFeatureCollection.java:125)
at org.geotools.feature.collection.BridgeIterator.next(BridgeIterator.java:31)
at org.geotools.feature.collection.BridgeIterator.next(BridgeIterator.java:18)
at org.geotools.renderer.lite.StreamingRenderer.drawPlain(StreamingRenderer.java:2494)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:2045)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:829)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:491)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:255)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:127)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:466)
at org.geoserver.wms.GetMap.run(GetMap.java:201)
at org.geoserver.wms.GetMap.run(GetMap.java:111)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:356)
at sun.reflect.GeneratedMethodAccessor250.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:61)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:35)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:73)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:54)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:54)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy24.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor260.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.geoserver.gwc.GWC.dispatchOwsRequest(GWC.java:1122)
at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:552)
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:497)
at org.geoserver.gwc.layer.GeoServerTileLayer.seedTile(GeoServerTileLayer.java:691)
at org.geowebcache.seed.SeedTask.doActionInternal(SeedTask.java:136)
at org.geowebcache.seed.GWCTask.doAction(GWCTask.java:76)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:36)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:25)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
