[Geoserver-devel] [jira] (GEOS-5964) Styling of GeoServer Admin header bar
Jonathan Moules created ImprovementGEOS-5964
Issue Type:
ImprovementImprovement
Affects Versions:
2.3.4
Assignee:
Andrea Aime
Components:
Wicket UI
Created:
09/Aug/13 7:04 AM
Description:
Currently the Admin page is identical on all instances. It is possible to change this manually by altering the .jar files, but that’s very sub-optimal (for one thing, they change with every new install).
Within the web-core-x.y.z.jar there is a file - org\geoserver\web\css\geoserver.css
Changing the #header “background: #fff;” (line 227/228) value to something else results in the header bar changing colour. This is a very effective way of allowing a admin to determine which server they are on in a multi-server environment.
Suggestion:
Provide a simple way for the user to alter this header background colour.
Ideally within the file that stores this, the colour would be associated with the URL:port of the instance (or some other unique-per-instance factor), so even multiple servers using the same GeoServer_Data_Dir can have different colours.
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
