james passmore created GEOS-5976 |
Issue Type: |
Improvement |
Assignee: |
Attachments: |
MapServerWMS-with-DataURLs.xml |
Components: |
WMS |
Created: |
16/Aug/13 12:57 PM |
Description: |
Consider this WMS service example, served using MapServer (GetCapabilities response attached). You can see that along with adding a MetadataURL to a layer it is also adding one or more DataURLs like: <DataURL> DataURL is one of the optional elements defined in the WMS schema (http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd) Wouldn’t it be good if you could do this in GeoServer too No doubt it is possible and I’ve just missed it somehow; if so please ignore this missive. |
Project: |
Priority: |
Minor |
Reporter: |
