[Geoserver-devel] [jira] (GEOS-5988) CSW spatial filters checks are too simplistic, do not work with a deeply nested schema
Andrea Aime created BugGEOS-5988
Issue Type:
BugBug
Assignee:
Justin Deoliveira
Components:
CSW
Created:
22/Aug/13 12:43 PM
Description:
The SpatialFilterChecker works fine against mostly flat models, or else, models that do have the geometry property as a directly child of the root node, but won’t work with a more nested structure.
Have the code delegate to the RecordDescriptor instead, which knows exactly where the spatial properties are, leaving SpatialFilterChecker as a utility for the simple cases
Project:
Priority:
MajorMajor
Reporter:
Andrea Aime
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
