[Geoserver-devel] [jira] (GEOS-5989) Ubuntu: Logging configs end up living in /var/lib/tomcat6/logs
Robert Coup created BugGEOS-5989
Issue Type:
BugBug
Affects Versions:
2.4-RC1
Assignee:
Justin Deoliveira
Components:
Configuration, Global
Created:
22/Aug/13 10:37 PM
Description:
The default distro-releases of tomcat6 in Ubuntu Lucid + Precise both:
  • Run Tomcat with a working directory of /var/lib/tomcat6
  • Have a logs/ dir (symlink) within that
When GlobalSettingsPage.logLevelsAppend() goes searching for available log configurations, it uses GeoServerResourceLoader.find("logs") which ends up finding /var/lib/tomcat6/logs rather than $GEOSERVER_DATA_DIRECTORY/logs.
This leads to (a) being unable to select anything other than the default logging config, and (b) the actual active logging configs being copied to /var/lib/tomcat6/logs (LoggingUtils.initLogging()) so changes to the data-dir ones don’t have any effect.
Seems that either:
  • LoggingUtils & GlobalSettingsPage should pass a parent (data-dir) into GeoServerResourceLoader.find(); or
  • the resource loader should check baseDirectory before relative paths with respect to the current working dir; or
  • Geoserver changes the CWD to data-dir on startup.
Thoughts?
Environment:
Ubuntu 10.04 + 12.04 with distro Tomcat6
Project:
Priority:
MinorMinor
Reporter:
Robert Coup
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
