Wouter Storteboom created GEOS-5996 |
Issue Type: |
Bug |
Affects Versions: |
2.3.3 |
Assignee: |
Created: |
26/Aug/13 7:38 AM |
Description: |
The GeoJSON output currently in Geoserver produces: According to http://www.geojson.org/geojson-spec.html#coordinate-reference-system-objects the preferred way should be: { “name”: “urn:ogc:def:crs:OGC:1.3:CRS84” } } I found this is a problem when working with the proj4leaflet plugin for Leafletjs. That plugin does not support the legacy way that Geoserver currently uses. I have also filed a bug report with the developer of the proj4leaflet plugin to support the legacy way. |
Environment: |
Geoserver 2.3.3 running on Glassfish 3.1.2 with JDK 17.0.25. |
Project: |
Priority: |
Major |
Reporter: |
