[Geoserver-devel] [jira] (GEOS-5997) Basic authentication filter message digest is not thread safe
Ly TRAN created BugGEOS-5997
Issue Type:
BugBug
Affects Versions:
2.3.3, 2.3.1
Assignee:
Andrea Aime
message_digest.patch
Created:
26/Aug/13 11:12 PM
Description:
Message digest is a member attribute of GeoServerBasicAuthenticationFilter. Therefore it is not thread safe in multi-thread environment.
Please find attached patch file contains a fix for making message digest thread safe as well as multi-threaded unit test.
The following intermittent exception is shown when sending a REST request to truncate layer’s cache:
2013-08-13 06:48:02.130::WARN: /geoserver/gwc/rest/seed/CBK_T_MINESTAR:CBK_T_ROADS.xml
java.lang.ArrayIndexOutOfBoundsException
at sun.security.provider.DigestBase.engineUpdate(DigestBase.java:110)
at sun.security.provider.MD5.implDigest(MD5.java:88)
at sun.security.provider.DigestBase.engineDigest(DigestBase.java:169)
at sun.security.provider.DigestBase.engineDigest(DigestBase.java:148)
at java.security.MessageDigest$Delegate.engineDigest(MessageDigest.java:546)
at java.security.MessageDigest.digest(MessageDigest.java:323)
at java.security.MessageDigest.digest(MessageDigest.java:369)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.getCacheKey(GeoServerBasicAuthenticationFilter.java:127)
at org.geoserver.security.filter.GeoServerSecurityFilter.authenticateFromCache(GeoServerSecurityFilter.java:90)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:47)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:46)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:103)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:730)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Project:
Priority:
MajorMajor
Reporter:
Ly TRAN
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
