Stefan Herle created GEOS-6045 |
Issue Type: |
Bug |
Affects Versions: |
2.3.3 |
Assignee: |
Components: |
Community modules, WPS |
Created: |
17/Sep/13 9:25 AM |
Description: |
We discovered a possible bug in the Scripting Extension when using 2 output parameters of mixed types: One literal output and one complex output from a geoscript geometry! Since some time the Scripting extension supports more than one output parameters by returning a dictionary instead of a raw result (String, Float, Gemotry, etc.) The Problem that occurred, is that our service executes without troubles but returns only one of the 2 provided outputs (The gemoetry)! |
Environment: |
We use the Python Scripting Extension with 2.3.3 |
Project: |
Labels: |
plugin |
Priority: |
Major |
Reporter: |
