[Geoserver-devel] [jira] (GEOS-6047) dependency for community importer-bdb module com.sleepycat:je:jar:4.1.10 not found in repositories
Marcus Sen created BugGEOS-6047
Issue Type:
BugBug
Affects Versions:
Assignee:
Andrea Aime
Components:
Community modules
Created:
24/Sep/13 10:31 AM
Description:
Trying to build importer module
mvn install in src/community/importer directory gives the error message:
Failed to execute goal on project importer-bdb: Could not resolve dependencies for project org.geoserver.importer:importer-bdb:jar:2.5-SNAPSHOT: Failure to find com.sleepycat:je:jar:4.1.10 in http://repo.opengeo.org/
Searching around this seems to be available at http://download.oracle.com/maven/com/sleepycat/je/4.1.10/je-4.1.10.jar but (as apparently seems typical with Oracle) this version isn’t listed in http://download.oracle.com/maven/com/sleepycat/je/maven-metadata.xml.
I don’t know whether there is an approved way of getting around this. Should the module maintainer provide an alternative repository or get it put in opengeo or…?
By chance I found http://maven.cci.emory.edu/nexus/content/repositories/aiw/com/sleepycat/je/4.1.10/ has this version in if that helps?
Project:
Priority:
MajorMajor
Reporter:
Marcus Sen
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
