Issue Type:
Bug
Affects Versions:
2.4.0
Assignee:
Rini Angreani
Components:
Application schema
Created:
26/Sep/13 10:44 AM
Description:
The following exception occurs when I try to map Geometry column into “gml:GeometryPropertyType” element :
Caused by: java.lang.IllegalArgumentException: Could not find working property accessor for attribute (GEOM) in object (SimpleFeatureImpl:MY_TABLE=[SimpleFeatureImpl.Attribute: FOREIGN_ID_0_0<String id=MY_TABLE.fid-44f4b6d5_1415ae40a25_-7ff9>=56, SimpleFeatureImpl.Attribute: FOREIGN_ID_1_0<String id=MY_TABLE.fid-44f4b6d5_1415ae40a25_-7ff9>=55])
at org.geotools.filter.AttributeExpressionImpl.evaluate(AttributeExpressionImpl.java:268)
at org.geotools.filter.AttributeExpressionImpl.evaluate(AttributeExpressionImpl.java:231)
at org.geotools.data.complex.DataAccessMappingFeatureIterator.getValues(DataAccessMappingFeatureIterator.java:460)
at org.geotools.data.complex.DataAccessMappingFeatureIterator.setAttributeValue(DataAccessMappingFeatureIterator.java:525)
at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:1012)
... 112 more
In the previous message, “GEOM” is the name of the Geometry column, and “MY_TABLE” is the name of the table.
Exactly the same workspace works with Geoserver-2.4RC1, but it doesn’t works with Geoserver-2.4.0.
Environment:
Oracle 11g,
Glassfish
Project:
Priority:
Major
Reporter:
Rudy Commenge
If you think it was sent incorrectly, please contact your JIRA administrators
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
