Issue Type:
Bug
Affects Versions:
2.4.0
Assignee:
Andrea Aime
Components:
Community modules
Created:
04/Oct/13 4:25 AM
Description:
Having just installed the printing plugin, I tried to generate a map on the demo page.
Here’s the error was logged by Tomcat:
java.lang.NoClassDefFoundError: org/apache/xerces/parsers/DOMParser
at org.mapfish.print.map.renderers.SVGTileRenderer.<clinit>(SVGTileRenderer.java:61)
at org.mapfish.print.map.renderers.TileRenderer.<clinit>(TileRenderer.java:41)
at org.mapfish.print.map.readers.HTTPMapReader.render(HTTPMapReader.java:81)
at org.mapfish.print.map.readers.WMSMapReader.render(WMSMapReader.java:76)
at org.mapfish.print.map.MapChunkDrawer.renderImpl(MapChunkDrawer.java:162)
at org.mapfish.print.ChunkDrawer.render(ChunkDrawer.java:55)
Manually installing the Xerces JAR file into WEB-INF/lib solved the issue.
Project:
Priority:
Critical
Reporter:
John Doe
If you think it was sent incorrectly, please contact your JIRA administrators
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
