Björn Harrtell created GEOS-6073 |
Issue Type: |
Bug |
Affects Versions: |
2.4.0 |
Assignee: |
Components: |
Wicket UI |
Created: |
04/Oct/13 9:08 AM |
Description: |
Same layer when running on Linux does not cause problems. Changing JRE default encoding to UTF-8 with -Dfile.encoding=UTF-8 does not help. Layer can be created with no problem but when trying to access configuration again I get the following exception: org.apache.wicket.WicketRuntimeException: Can’t instantiate page using constructor public org.geoserver.web.data.resource.ResourceConfigurationPage(org.apache.wicket.PageParameters) and argument name = “[MU_BÃÂ TPLATSER]” wsName = “[gkdb]” The URL that is generated is: I think the URL params should perhaps use internal id instead of name to avoid these kind of problems. |
Environment: |
Windows Server 2003 |
Project: |
Priority: |
Major |
Reporter: |
