[Geoserver-devel] [jira] (GEOS-6077) Create an endpoint for webapps to authenticate against
Justin Deoliveira created ImprovementGEOS-6077
Issue Type:
ImprovementImprovement
Affects Versions:
2.4.0
Assignee:
Justin Deoliveira
Components:
Security
Created:
07/Oct/13 10:42 AM
Description:
Pre 2.4.x webapps could utilize the fact that the j_spring_security_check endpoint sent back a cookie that the app could use to authenticate on subsequent requests. This has changed with the geoserver form login updates on 2.4.x.
As stat3ed in GEOS-6076 a better approach would be a dedicated login/logout endpoint designed for webapps.
Project:
Priority:
MajorMajor
Reporter:
Justin Deoliveira
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
