Niki Hammerschmidt created GEOS-6098 |
Issue Type: |
Bug |
Affects Versions: |
2.4.0 |
Assignee: |
Created: |
17/Oct/13 3:15 AM |
Description: |
I’m trying to create a Layer from a costum SQL-Statement. This fails due to a comment in the last line. Example: select The Geoserver tries to determine the columns of the query by adding some SQL which makes it fail: select * from (select To fix this, you’ll probably just need to add a newline to the query, before adding the ‘) as “vtable” where 1 = 0’ |
Environment: |
Windows 7 Professional x64 running Geoserver, Windows Server 2012 running MSSQL 2012 |
Project: |
Priority: |
Critical |
Reporter: |
