[Geoserver-devel] [jira] (GEOS-6104) add featuretypename/tablename to exception message of spatial operations
Rudi Hochmeister created ImprovementGEOS-6104
Issue Type:
ImprovementImprovement
Affects Versions:
2.3.5
Assignee:
Andrea Aime
Components:
Oracle
Created:
22/Oct/13 5:01 AM
Description:
instead of “java.io.IOException: Error occured calculating bounds” it
would be very helpful to print featuretypename or tablename additionally without need to increase the log level afterwards and try to reproduce. So that the log reads: “java.io.IOException: Error occured calculating bounds for Featuretypename/Tablename”
imho I guess that would be very helpful for fast error search - at least for me (when the prod logs from day before contain dozens of those messages like “Error ocurred doing something”) and you dont know where to start because there are no ft-names
Environment:
geoserver with oracle datastore
Project:
Priority:
MinorMinor
Reporter:
Rudi Hochmeister
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
