[Geoserver-devel] [jira] (GEOS-6112) Upgrading geoserver 2.3.2 to 2.4 does not transform context.xml correctly
Eric Smets created BugGEOS-6112
Issue Type:
BugBug
Affects Versions:
2.3.2
Assignee:
Justin Deoliveira
config.xml.2.3
Components:
Configuration
Created:
24/Oct/13 2:38 AM
Description:
GeoServer does not start-up with data tree from geoserver 2.3.2
  • Following Error was found in the localhost… log file.
  • No Error in catalina log file was found
EVERE: Exception sending context initialized event to listener instance of class org.geoserver.platform.GeoServerContextLoaderListener
java.lang.RuntimeException: org.geoserver.security.validation.SecurityConfigException: The anonymous filter must be the last filter in filter chain “web”
at org.geoserver.security.GeoServerSecurityManager.onApplicationEvent(GeoServerSecurityManager.java:327)
at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:97)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:324)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:25)
Environment:
debian linux, oracle java 1.7, tomcat 7
Project:
Priority:
MajorMajor
Reporter:
Eric Smets
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
