[Geoserver-devel] [jira] (GEOS-6117) Weird contour lines on flat areas
Christophe Delépine created BugGEOS-6117
Issue Type:
BugBug
Assignee:
Andrea Aime
Created:
28/Oct/13 10:45 AM
Description:
The contour lines generation looks buggy on flat areas. See snapshots
Note that the lines in blue are contour lines at 140 m altitude generated with GlobalMapper from the same raster source. This makes it easy for you to compare the 2 algorithms
Environment:
GeoServer 2.4.1 (+ patch contour lines)
JRE 1.7
XP 64
Project:
Priority:
MajorMajor
Reporter:
Christophe Delépine
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
