[Geoserver-devel] [jira] (GEOS-6139) "this should never happen!" error.
Jonathan Moules created BugGEOS-6139
“this should never happen!” error.
Issue Type:
BugBug
Affects Versions:
2.4.1
Assignee:
Andrea Aime
Created:
06/Nov/13 6:06 AM
Description:
This may be related to 6138.
One of my GeoServer instances was failing with WFS GetCapabilities requests, as well as GetMap requests. The stack trace includes the rather ominous “this should never happen!”. Restarting the instance resolved the issue eventually.
Using an Oracle NG store - Validate connections is off.
2013-11-06 11:13:22,576 WARN [geotools.jdbc] - Error occurred closing connection
2013-11-06 11:13:22,592 ERROR [geoserver.ows] -
java.lang.RuntimeException: Error getting FeatureType, this should never happen!
at org.geoserver.wms.map.GetMapKvpRequestReader.checkStyle(GetMapKvpRequestReader.java:1134)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:399)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:80)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1412)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:87)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:615)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:879)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:600)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1703)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: Error occurred getting table name list.
at org.geotools.jdbc.JDBCDataStore.createTypeNames(JDBCDataStore.java:891)
at org.geotools.data.store.ContentDataStore.entry(ContentDataStore.java:562)
at org.geotools.data.store.ContentDataStore.ensureEntry(ContentDataStore.java:593)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:385)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:352)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:336)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:678)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:104)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:858)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:814)
at org.geoserver.catalog.impl.FeatureTypeInfoImpl.getFeatureType(FeatureTypeInfoImpl.java:87)
at org.geoserver.wms.map.GetMapKvpRequestReader.checkStyle(GetMapKvpRequestReader.java:1130)
… 85 more
Caused by: java.sql.SQLException: Io exception: Connection reset
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:112)
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:146)
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:255)
at oracle.jdbc.driver.T4CStatement.executeForDescribe(T4CStatement.java:806)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1037)
at oracle.jdbc.driver.T4CStatement.executeMaybeDescribe(T4CStatement.java:830)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1132)
at oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1272)
at oracle.jdbc.OracleDatabaseMetaData.getTableTypes(OracleDatabaseMetaData.java:2555)
at org.apache.commons.dbcp.DelegatingDatabaseMetaData.getTableTypes(DelegatingDatabaseMetaData.java:591)
at org.geotools.jdbc.JDBCDataStore.createTypeNames(JDBCDataStore.java:856)
… 96 more
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
