[Geoserver-devel] [jira] (GEOS-6148) GEoServer 2.4.1 saves new layers with broken coordinates
Fredrik Ekström created BugGEOS-6148
Issue Type:
BugBug
Affects Versions:
2.4.1
Assignee:
Andrea Aime
Components:
Created:
12/Nov/13 4:57 AM
Description:
When i register a new layer from PostGIS and calculate the bounding box from data i get the right extent but when i save geoserver dos someting wrong and cuts of all the coorinates
My SRID is 3008 by the way, This error first occurred in 2.3.5 if i remember correctly.
I have tested with a clean install + new database = same problem
My workaround is the manaaly edit the featuretype.xml after i save and rewrite the coordinates.
Sorry for my bad english, been a while since a last wrote in english. I hope for i quick fix for this, seems to me like it cuts of the coordinates at the first space…
Environment:
Windows Server 2008 R2 Datacenter
Project:
Priority:
MajorMajor
Reporter:
Fredrik Ekström
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
