[Geoserver-devel] [jira] (GEOS-6168) Release src.xml does not exclude target
Ben Caradoc-Davies created BugGEOS-6168
Issue Type:
BugBug
Affects Versions:
2.5-beta
Assignee:
Andrea Aime
Components:
Global
Created:
18/Nov/13 7:11 PM
Description:
Release src.xml does not exclude target directories, resulting a >200 MB src zip. Looks like this has been the case for years. See file sizes:
http://files.ivec.org/geoserver/geoserver-master/2013-11-19/
The culprit is the inclusion of target directories after a full build. I can see the exclude rules but they do not work, and I do not know what is wrong.
Assembly was performed with:
mvn -B -nsu assembly:attached
I suspect Boundless Jenkins builds source jars in a clean working directory, concealing this problem, and producing src zips of a reasonable size.
Project:
Priority:
MinorMinor
Reporter:
Ben Caradoc-Davies
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
