Michaël Michaud created GEOS-6180 |
Issue Type: |
Bug |
Affects Versions: |
2.4.1 |
Assignee: |
Components: |
WMS |
Created: |
21/Nov/13 8:35 AM |
Description: |
We use the vendorOption “spaceAround” with a negative value (-1) which disables conflict resolution. It seems very likely that the spaceAround parameter is converted and “rounded”, and that some negative values (> -1 or >-0.5), after conversion are rounded to 0. Hence the erroneous behaviour (conflict resolution is no more disabled despite the negative value set by the user, and more important, result depends on the zoom level). Michaël Michaud |
Project: |
Priority: |
Minor |
Reporter: |
