[Geoserver-devel] [jira] (GEOS-6182) Execute goes NPE if the responseForm is missing in the request
Andrea Aime created BugGEOS-6182
Issue Type:
BugBug
Assignee:
Andrea Aime
Components:
WPS
Created:
22/Nov/13 4:13 AM
Description:
A request as follows will make the WPS output writing code go NPE:
<wps:Execute version="1.0.0" service="WPS" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.opengis.net/wps/1.0.0" xmlns:wfs="http://www.opengis.net/wfs" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:wcs="http://www.opengis.net/wcs/1.1.1" xmlns:xlink="http://www.w3.org/1999/xlink" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">
  <ows:Identifier>JTS:area</ows:Identifier>
  <wps:DataInputs>
    <wps:Input>
      <ows:Identifier>geom</ows:Identifier>
      <wps:Reference mimeType="text/xml; subtype=gml/3.1.1" xlink:href="http://geoserver/wps" method="POST">
        <wps:Body>
          <wps:Execute version="1.0.0" service="WPS">
            <ows:Identifier>JTS:buffer</ows:Identifier>
            <wps:DataInputs>
              <wps:Input>
                <wps:Data>
                  <wps:ComplexData mimeType="application/wkt"><![CDATA[POINT(0 0)]]></wps:ComplexData>
                </wps:Data>
              </wps:Input>
              <wps:Input>
                <ows:Identifier>distance</ows:Identifier>
                <wps:Data>
                  <wps:LiteralData>10</wps:LiteralData>
                </wps:Data>
              </wps:Input>
            </wps:DataInputs>
            <wps:ResponseForm>
              <wps:RawDataOutput mimeType="text/xml; subtype=gml/3.1.1">
                <ows:Identifier>result</ows:Identifier>
              </wps:RawDataOutput>
            </wps:ResponseForm>
          </wps:Execute>
        </wps:Body>
      </wps:Reference>
    </wps:Input>
  </wps:DataInputs>
</wps:Execute>
Adding the response form fixes it:
  <wps:DataInputs>
    <wps:Input>
        <wps:Body>
            <wps:DataInputs>
              <wps:Input>
                <wps:Data>
                </wps:Data>
              </wps:Input>
              <wps:Input>
                <wps:Data>
                </wps:Data>
              </wps:Input>
            </wps:DataInputs>
            <wps:ResponseForm>
            </wps:ResponseForm>
          </wps:Execute>
        </wps:Body>
      </wps:Reference>
    </wps:Input>
  </wps:DataInputs>
  <wps:ResponseForm>
    <wps:RawDataOutput>
  </wps:ResponseForm>
</wps:Execute>
However, from the WPS schemas, the response form is an optional element, so the code should work regardless.
Project:
Priority:
MajorMajor
Reporter:
Andrea Aime
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
