[Geoserver-devel] [jira] (GEOS-6188) The CAS extension can't be loaded correctly
Nazzareno Sileno created BugGEOS-6188
The CAS extension can’t be loaded correctly
Issue Type:
BugBug
Affects Versions:
2.4.2, 2.4.1
Assignee:
Andrea Aime
GSWebAppCasDependencyFix.patch, pathCasStartup.patch
Components:
UI
Created:
25/Nov/13 9:27 AM
Description:
Since GS 2.4.1 version the CAS extension can’t be loaded because the web-sec-cas applicationContext.xml is not correctly positioned. In addition, there is an error declaring the cas profile dependency on web-app module. The group id for web-sec-cas is incorrect.
Environment:
Linux Mint
Fix Versions:
2.4.2
Project:
Priority:
BlockerBlocker
Reporter:
Nazzareno Sileno
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
