[Geoserver-devel] [jira] (GEOS-6195) WMTS does not declare Time dimension in GetCapabilities
Jeroen Dries created BugGEOS-6195
Issue Type:
BugBug
Affects Versions:
2.4.2
Assignee:
Andrea Aime
Components:
GWC
Created:
27/Nov/13 3:10 AM
Description:
My WMS correctly declares the time dimension like this:
<Dimension name="time" default="current" units="ISO8601">
2013-06-21T00:00:00.000Z,2013-10-11T00:00:00.000Z,2013-10-21T00:00:00.000Z,2013-11-01T00:00:00.000Z,2013-11-11T00:00:00.000Z
</Dimension>
However, in the corresponding WMTS layer declaration, the time dimension is not present. The WMTS spec does allow this. This example can be found on schemas.opengis.net:
<Layer>
  <ows:Title>Coastlines</ows:Title>
  <ows:Abstract>Coastline/shorelines (BA010)</ows:Abstract>
  <ows:WGS84BoundingBox>
    <ows:LowerCorner>-180 -90</ows:LowerCorner>
    <ows:UpperCorner>180 90</ows:UpperCorner>
  </ows:WGS84BoundingBox>
  <ows:Identifier>coastlines</ows:Identifier>
  <Style isDefault="true">
    <ows:Title>Dark Blue</ows:Title>
    <ows:Identifier>DarkBlue</ows:Identifier>
    <LegendURL format="image/png"     xlink:href="http://www.miramon.uab.es/wmts/Coastlines/coastlines_darkBlue.pn g"/>
  </Style>
  <Style>
   <ows:Title>Thick And Red</ows:Title>
   <ows:Abstract>
    Specify this style if you want your maps to have thick red coastlines.
   </ows:Abstract>
   <ows:Identifier>thickAndRed</ows:Identifier>
  </Style>
  <Format>image/png</Format>
  <Format>image/gif</Format>
  <Dimension>
    <ows:Title>Time</ows:Title>
    <ows:Abstract>Monthly datasets</ows:Abstract>
    <ows:Identifier>TIME</ows:Identifier>
    <Value>2007-05</Value>
    <Value>2007-06</Value>
    <Value>2007-07</Value>
   </Dimension>
   <TileMatrixSetLink>
    <TileMatrixSet>BigWorld</TileMatrixSet>
   </TileMatrixSetLink>
</Layer
Project:
Priority:
MajorMajor
Reporter:
Jeroen Dries
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
