Jody Garnett created GEOS-6210 |
Issue Type: |
Bug |
Affects Versions: |
2.4.0 |
Assignee: |
Components: |
CSS |
Created: |
02/Dec/13 2:54 AM |
Description: |
Here is an interesting one, because it conflicts with the documentation example. When constructing my own example of a compound label using ne:roads: Unable to find source-code formatter for language: css. Available languages are: actionscript, html, java, javascript, none, sql, xhtml, xml
I also tried replacing with direct use of Concatinate: Unable to find source-code formatter for language: css. Available languages are: actionscript, html, java, javascript, none, sql, xhtml, xml
The result shows no separation of content. Adding a any non white space character to the separating string causes the white space to be respected: Unable to find source-code formatter for language: css. Available languages are: actionscript, html, java, javascript, none, sql, xhtml, xml
Environment: |
OSX |
Project: |
Priority: |
Major |
Reporter: |
