[Geoserver-devel] [jira] (GEOS-6220) When ImageMosaicJDBC data source, the configuration file is not re-read until GeoServer is restarted
Tuure Laurinolli created BugGEOS-6220
Issue Type:
BugBug
Assignee:
Andrea Aime
Created:
09/Dec/13 5:14 AM
Description:
When creating an ImageMosaicJDBC raster data source, the config file of the Geotools ImageMosaic reader is given as URL. The file that the URL points to is read only once. This makes it difficult to add new layers, since fixing any errors in the configuration requires restarting GeoServer or renaming the configuration file.
The problems is apparently caused by caching of config files in Geotools. I will create a separate issue there.
Project:
Priority:
MinorMinor
Reporter:
Tuure Laurinolli
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
