Marcus Sen created GEOS-6233 |
Issue Type: |
Bug |
Affects Versions: |
2.4.2 |
Assignee: |
Components: |
Application schema |
Created: |
16/Dec/13 6:22 AM |
Description: |
If I install GeoServer and then set the data directory to be the tutorial data that comes with the app-schema plugin and execute the query below: I get the error response: <ows:ExceptionReport version=“2.0.0” xsi:schemaLocation=“http://www.opengis.net/ows/1.1 http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd”><ows:Exception exceptionCode=“OperationProcessingFailed” locator=“GetFeature”><ows:ExceptionText>No feature types specified</ows:ExceptionText></ows:Exception></ows:ExceptionReport> With a stored query, it shouldn’t be necessary to specify a feature type. Note the core GeoServer WFS partly supports this query although the response isn’t quite the correct format: see https://jira.codehaus.org/browse/GEOS-6232 |
Environment: |
Windows 7 |
Project: |
Priority: |
Minor |
Reporter: |
