[Geoserver-devel] [jira] (GEOS-6234) Explicit advise on character encoding in the cURL-example
Hartmut Noack created ImprovementGEOS-6234
Issue Type:
ImprovementImprovement
Assignee:
Andrea Aime
curl.rst
Components:
Documentation
Created:
16/Dec/13 6:22 AM
Description:
In order to avoid problems with unescaped chars in requests sent via cURL and/or curl-implementations in PHP, I have written 2 more paragraphs in doc/en/user/source/rest/examples/curl.rst (file attached).
It is not perfectly the best solution, for it is somewhat hidden in the rest-section while it applies to many other use-cases too. So I would like to write an entirely new page for the tutorials-section to cover the use of curl in PHP to send requests, including some hints on how to append cql-filters and how to use the csv-output of wfs. If this should be welcome
Environment:
All
Project:
Labels:
documentation
Priority:
MinorMinor
Reporter:
Hartmut Noack
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
