sanguinela sdxcv created GEOS-6237 |
Issue Type: |
Bug |
Affects Versions: |
2.4.0 |
Assignee: |
Created: |
17/Dec/13 9:51 AM |
Description: |
hi all it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL I resolved the problem (I read the solution here: http://geo-solutions.blogspot.it/2010/02/fix-gdal-extension-not-working-with.html) But now I have another problem: AVVERTENZA: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won’t be enabled. My goal is install this: http://docs.geoserver.org/stable/en/user/data/raster/gdal.html thank all |
Environment: |
win7_64bits / jdk 1.6.0_45(64bits) (I tried also with 32bits) / GDAL 1.9.2, released 2012/10/08 |
Project: |
Priority: |
Major |
Reporter: |
