[Geoserver-devel] [jira] (GEOS-6242) Labels wronly overlapping when conflictResolution off
Jonathan Moules created BugGEOS-6242
Issue Type:
BugBug
Affects Versions:
2.4.1
Assignee:
Andrea Aime
Created:
19/Dec/13 6:41 AM
Description:
See attached.
Both layers are in the same LayerGroup, the “Nuneaton” label is coming from a layer that should be on top of the road text layer (this is correctly set - those labels are rendering on top of the road line features).
The “Nuneaton” layer text has “<se:VendorOption name=“conflictResolution”>false</se:VendorOption>”
The road text has this set to true.
If I change the Nuneaton Layer to “true” as well, then the road text won’t be rendered and so the overlap will have resolved itself.
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
