[Geoserver-devel] [jira] (GEOS-6244) Image Mosaic reprojection from 900913 to 4326 causes Geoserver to crash
Nikolaus Pruzsinszky created BugGEOS-6244
Issue Type:
BugBug
Affects Versions:
2.3.4
Assignee:
Andrea Aime
Created:
20/Dec/13 6:13 AM
Description:
I have got an Image Mosaic with about 10 Geotiffs (inner tiling, overviews), all in all about 1 GB, they are all in EPSG 900913 (web mercator).
When I try to view them in WGS84 (EPSG 4326), I get nothing or pink tiles and the following error:
2013-12-19 07:55:09,266 WARN [geotools.rendering] - Requested region cannot be represented by a single Raster.
java.lang.IllegalArgumentException: Requested region cannot be represented by a single Raster.
at javax.media.jai.PlanarImage.getData(PlanarImage.java:2163)
at javax.media.jai.RenderedOp.getData(RenderedOp.java:2276)
at sun.java2d.SunGraphics2D.drawRenderedImage(SunGraphics2D.java:2615)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.paint(GridCoverageRenderer.java:923)
at org.geotools.renderer.lite.StreamingRenderer$RenderRasterRequest.execute(StreamingRenderer.java:3487)
at org.geotools.renderer.lite.StreamingRenderer$PainterThread.run(StreamingRenderer.java:3590)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:724)
Afterwards, I can still access the web interface, but all requests return pink tiles and I have to restart geoserver.
When I try to project the single geotiffs, I do not encounter this problem.
Project:
Labels:
extension raster mosaic projection
Priority:
MajorMajor
Reporter:
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
