[Geoserver-devel] [jira] (GEOS-6256) add "purge" parameter to REST delete
Daniele Romagnoli created ImprovementGEOS-6256
add “purge” parameter to REST delete
Issue Type:
ImprovementImprovement
Assignee:
Daniele Romagnoli
Components:
REST
Created:
07/Jan/14 5:45 AM
Description:
As per 1 it would be great to allow a delete operation on Structured GridCoverage Readers.
It would also be good to integrate this capability in GeoServer through REST delete coverageStore call 2.
On such a topic we should also add a new “purge” parameter beside the “recurse” one 3 for the delete op.
It may have 3 values:
none –> the default… to be backward compatible with the current REST delete store behaviour)
metadata -> in order to delete only metadata, and auxiliary files… no granules will be deleted)
all -> in order to delete everything (metadata and granules too)
Project:
Priority:
MinorMinor
Reporter:
Daniele Romagnoli
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
