chandler david created GEOS-6266 |
Hello everyone,
I have a raster layer published with imagemosaic which return rendering errors on occasion (message " Rendering process failed
Unable to create this mosaic null", see below for the logs).
It is difficult to tell exactly what is the cause of this, but I 'm pretty sure that errors occured when the output resolution image is lower than the native raster resolution ( for example if I want a 4 m/pixel resolution and native image is 2 Meter/pixels)
AND when image mosaic appears to have no data on the bounding box requested .
Until Geoserver 2.4.2 , a blank (but valide) image was delivered, with 2.4.3 we have this error now.
I wonder if this new behavior is connected to this recent bug fix:GEOS-6197
please find geoserver’s log attached.
regards,
Dchandler
Environment:Linux,Windows ServerProject:GeoServerPriority:MajorReporter:chandler david
Issue Type: |
Bug |
Affects Versions: |
2.4.3 |
Assignee: |
Attachments: |
logs.txt |
Components: |
Image mosaic JDBC |
Created: |
13/Jan/14 10:50 AM |
Description: |
If you think it was sent incorrectly, please contact your JIRA administrators
