[Geoserver-devel] [jira] (GEOS-6287) WFS: actual SRS styles not documented
Bernhard Kiselka created BugGEOS-6287
The documentation
http://docs.geoserver.org/latest/en/user/webadmin/services/WFS.html
does not match GeoServer 2.4.2:
Documented is (and has been in GeoServer 2.1.3): Normal, XML, URN
The list of SRS styles is now in GeoServer 2.4.2: EPSG Code, OGC HTTP URL, OGC Experimental URN, OGC URN, OGC HTTP URI
GEOS-4545 may have caused this bug, looking at
https://github.com/geoserver/geoserver/commit/cfbe8390c60498f489649151de093ce690ef2491
the matching is the ordering:
Normal → EPSG Code
XML → OGC HTTP URL
URN → OGC Experimental URN
I found a description at
http://docs.geotools.org/stable/javadocs/org/geotools/gml2/SrsSyntax.html
Maybe this documentation should be adapted as well:
http://docs.geoserver.org/latest/en/user/services/wfs/basics.html#axis-ordering
Environment:Windows 7, JBossProject:GeoServerPriority:MajorMajorReporter:Bernhard Kiselka
Issue Type:
BugBug
Affects Versions:
2.4.2
Assignee:
Andrea Aime
Components:
Documentation, WFS
Created:
16/Jan/14 9:55 AM
Description:
If you think it was sent incorrectly, please contact your JIRA administrators
