Daniele Romagnoli created an issue |
Use direct read when CoverageBuilder creates a sample 5x5 coverage |
Issue Type: |
Improvement |
Affects Versions: |
2.5-beta |
Assignee: |
Created: |
31/Jan/14 9:43 AM |
Fix Versions: |
2.5-rc1 |
Priority: |
Minor |
Reporter: |
The CoverageBuilder does a minimal (5x5 at most) coverage read to retrieve some coverage properties. In case the input formats supports the USE_JAI_IMAGEREAD parameter it uses its default value which is True. Pull request available. |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
