[Geoserver-devel] [jira] (GEOS-6350) JSONP callback syntax is non-standard and is impossible to use in certain libraries (jquery)
Calvin Metcalf created an issue
GeoServer / BugGEOS-6350
Issue Type:
BugBug
Assignee:
Andrea Aime
Components:
REST
Created:
18/Feb/14 5:00 AM
Priority:
MajorMajor
Reporter:
Calvin Metcalf
There is a de facto standard for JSONP that a user can specify the callback with the syntax callback=?, libraries like jQuery assume that the callback will be a value like that (or less common something like jsonp_callback) Geoserver only allows it to be specified as part of a longer value FORMAT_OPTIONS=callback%3A? while there may be some internal reasons that that syntax is necessary there is not reason it needs to be externally visable and the query param processor (or whatever it is exactly that reads them) could map callback=? to FORMAT_OPTIONS=callback%3A?.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
