The two UPS projections EPSG:32761 and EPSG:32661 have the two axis swapped. Well, that itself does not seem to be a bug, but it seems like someone has decided it was a good idea to swap these for some strange reason. According to http://spatialreference.org/ref/epsg/32661/ogcwkt/ the axis should be Easting-Northing. The fact that these are not following the standard causes some issues when I’m trying to combine the data with layers from other WMS’.
The corresponding projections which are supposed to have the correct axis EPSG:5041 and EPSG:5042, are not working.
I’m getting this nice little error with a stack trace when trying to fetch them:
19 feb 10:24:46 ERROR [geoserver.ows] -
org.opengis.parameter.ParameterNotFoundException: Parameter “standard_parallel_1” is missing.
at org.geotools.parameter.ParameterGroup.parameter(ParameterGroup.java:321)
at org.geotools.renderer.crs.PolarStereographicHandlerFactory.getHandler(PolarStereographicHandlerFactory.java:45)
at org.geotools.renderer.crs.ProjectionHandlerFinder.getHandler(ProjectionHandlerFinder.java:84)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:779)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:481)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:251)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:123)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:521)
at org.geoserver.wms.GetMap.run(GetMap.java:253)
at org.geoserver.wms.GetMap.run(GetMap.java:124)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:328)
at sun.reflect.GeneratedMethodAccessor197.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:61)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:35)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:73)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:54)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:54)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy58.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor184.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
It might be that this issue belongs in GeoTools, and not GeoServer
