Jonas Reinhardt created an issue |
Issue Type: |
Improvement |
Assignee: |
Components: |
Documentation |
Created: |
19/Feb/14 11:19 AM |
Priority: |
Minor |
Reporter: |
Working on meta-tiling and trying to understand the tiled parameter I found the documentation and example unclear. In
and in the OpenLayers example below it is written as
Are both valid? Under the tiled parameter it is stated that:
Probably wrong or? The meta-tiling is hardly functioning without the above example… |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
