Rini Angreani created an issue |
WMS GetMap fails when default geometry has a different namespace to the feature type |
Issue Type: |
Bug |
Assignee: |
Components: |
WMS |
Created: |
19/Feb/14 11:04 PM |
Fix Versions: |
2.5-rc1 |
Priority: |
Major |
Reporter: |
Request: gsml/wms?service=WMS&version=1.1.0&request=GetMap&layers=gsml:Borehole&styles=&bbox=-180.0,-90.0,180.0,90.0&width=660&height=330&srs=EPSG:4326&format=image%2Fjpeg Error: <ServiceException code=“internalError”> However, it works for gsmlp:BoreholeView. I suspect this is because in gsml:Borehole, the shape has a different namespace (sa:shape), and the WMS assumes the feature namespace i.e. gsml. It works for gsmlp:BoreholeView because it uses gsmlp:shape. It would probably work if we explicitly define the geom attribute (sa:shape) in the SLD. The bug is when it’s trying to guess the default geom. |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
