[Geoserver-devel] [jira] (GEOS-6371) halo not centered on label
Kay F. Jahnke created an issue
GeoServer / BugGEOS-6371
Issue Type:
BugBug
Affects Versions:
2.4.4
Assignee:
Andrea Aime
Components:
WMS
Created:
26/Feb/14 8:42 AM
Environment:
Kubuntu 12.04 on 32bit intel, geoserver on tomcat7
Labels:
WMS rendering halo icon
Priority:
MinorMinor
Reporter:
Kay F. Jahnke
I have started this thread on geoserver-users:
http://sourceforge.net/p/geoserver/mailman/geoserver-users/thread/CA%2BnxMTtVBfYNYgC-o7aZBoSzgUwDAgOE0LP84zWDhdVOqrYnQg%40mail.gmail.com/#msg32028302
                  • begin quote of relevant section
I have a problem with geoserver’s rendering of halos and icons, as can
be seen in this enlarged screenshot of the WMS output:
https://www.dropbox.com/s/a226o6yb01flu9n/geoserver_icon_problem2.png
As you can see, the halo around the spot height is not centered around
the ciphers; instead it looks like it has has slipped down by one pixel,
so there is no halo above the ciphers, but a halo below which is wider
than one pixel.
                                          • end quote
While I was told that a fix for the icon problem is in the pipeline, I mention it again because it might be connected with the halo problem; the symptoms are very similar. The halo problem occurs only on specific label+zoom level combinations and can be reproduced. It is not affected by scrolling and panning.
Kay
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
